Granatelli MAF Sensor
Car: 85 z28
Engine: 87 corvette 5.7L
Axle/Gears: 9 bolt australian 3.42
Hello there, I was wondering if anybody here has used a Granatelli Mass air flow sensor? I think my sensor just went out and i found this good deal on a Granatelli. Is it a performance upgrade or simply a replacement? Thanks.
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Granatelli MAF Sensor
From what I gather the id of the housing is larger than oem Bosch. I have also been told it is the same as the microtech. I dont see a benifit unless on its adjustability it has a higher gps range. You will need a pretty stout stroker to need to go to a different maf and there is code change for $32B for a ford maf IIRC bye TequilaBoy .
Car: 85 z28
Sucks to hear that. I found one on craigslist still in the original package for 150 and so i took the chance on it. I tested it and i cant really tell if it improved the performance since my trans lost 3d and overdrive. Im swapping in another trans out tonite and tomorrow so i should know by friday.
Car: 1985 IROC-Z
Engine: 355 LT1
Transmission: 4L60
Axle/Gears: 3.23 Australian 9 bolt
my understanding is this is one of those parts that you get after you are already fast (exceeding factory capabilities) not one that gives you any noticeable gaines. unless you are tuning, seems like thats the only way to get the aftermarkets to perform.
Car: 85 z28
Oh ok. That makes sense to me. Well as long as i dont have to buy another stock maf for a while ill be happy.
BumpaD82
Feb 26, 2016 02:57 PM
[For Sale] 4" Spectre MAF Housing/LS7 MAF/Coupler
Ikes 91Z
LSX and LTX Parts
Sep 13, 2015 09:03 AM
