1992 TPI Manifolds
Car: Chevy Pickup
Transmission: muncie
Axle/Gears: 373
1992 TPI Manifolds
Hi Guys Need your help. I have a 1992 Camaro z28 with the 305 tpi. I put a L98 out of a 90 corvette in the car and used the vette aluminum heads. I tried to bolt up the tpi from the 305 I had and the ports matched up but the bolt holes didnt. I had to grind the manifold bolt holes longer to get the bolts to go into the heads. Why did this happen? are the 350 (5.7) and the 305 (5.0) manifolds different in some way ? Thanks !
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: 1992 TPI Manifolds
The corvette manifold has a rear coolant crosover for better cooling. The bolt pattern of the Y l98 is 55-86 . The Y-manifold also has the reag egr feed as well as the center exhauset feed but the 113s do not have a passage other than the rear.
Car: Chevy Pickup
Axle/Gears: 373
Ok is the 305 tpi manifold useable on the 350 ? and Why do the bolt holes not line up? ( i had to elongate the holes )
Car: Chevy Pickup
Axle/Gears: 373
then why do the the manifold bolt holes not line up. The 305 tpi manifold is use able on the 350 Right?
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Car: 82 Z28
Transmission: T400
just like the aftermarket intakes where one version fits both style heads
You may need a large washer under the bolt head on those 4 holes to spread the weight correctly for gasket clamping
Note the aftermarket version has 2 different flats machined to suit the stock bolt head
Sanjay
Aug 12, 2015 03:41 PM
