Is it normal to leak a little coolant after t/b bypass?
Car: 1985 IROC-Z
Just finished with t/b bypass and put rubber caps on the unused inlet/outlet. Took it for a 3 minute drive and there is a little coolant now on top of motor. Anyone know if this is normal and will stop? Do i need to put hose clamps on the rubber end caps? I am assuming that is where it is coming from because it didn't happen before the bypass. Thanks.
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
Re: Is it normal to leak a little coolant after t/b bypass?
No need for any caps at all. It must be just leftover coolant in the TB.
If you want to use the caps for style, Just leave them off for a while until all the water boils out before you put the caps back on.
Car: 1988 Pontiac Trans Am GTA.
Engine: 385 stroker sbc
Transmission: TKO600
Axle/Gears: Moser 9" 3.70 Wavetrac
If you have a fluid pump, pump out the coolant. Im sure it is 1-2oz tops
