I came to the conclusion that my ECM is broke!
Old Apr 30, 2014 | 01:49 PM
captainchadl's Avatar
Car: 1987 IROC - Z
Engine: 5.0 TPI
I have been having some weird, to say the least, problems with my car. Problems such as not wanting to fire up right away and not firing up at all. I had the ignition control module (the one located under the distributor cap) tested and it was fine. I stopped at Napa to get a new relay for my auxiliary coolant fan and for the mass air flow burn off circuit, because I kept getting a code for the burn off relay. Then when I replaced the relays for the auxiliary coolant fan, the fan still wouldn't come on. So, out came the multi-meter When I tested the wires that activated the relay I had 12v at each one. I then unplugged the ecm, and checked the wire for voltage at the connection of the harness ( not the ecm), and I have no voltage. I then plugged the ecm back into the harness and tested that wire and had 12v. The circuit I am referring to is d11 from the ecm. I did all the testing with terminals a and b jumped. So, my conclusion is that I am getting 12 volts from the ecm where I should be a ground.
Old Apr 30, 2014 | 06:03 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: I came to the conclusion that my ECM is broke!
Originally Posted by captainchadl
unplugged the ecm, and checked the wire for voltage at the connection of the harness , and I have no voltage.
What ECM?
Old Apr 30, 2014 | 06:05 PM
Blue1990camaro's Avatar
well a ground will show 12v should it not if the circuit is closed?
Old May 1, 2014 | 09:07 AM
Car: 1987 IROC - Z
Engine: 5.0 TPI
It should, but the circuit was open when I tested it. I had both relays removed.
Attached Thumbnails I came to the conclusion that my ECM is broke!-fig37_1988_5_7l_tuned_port_injection_engine_wiring.gif
Old May 1, 2014 | 12:32 PM
Car: 1987 IROC - Z
Engine: 5.0 TPI
So, I have 12 volts coming out of Pin d11 on the ecm (engine control module). I cut the wire coming directly from d11 so that I could eliminate any possibility of a short somewhere else in the harness.
Old May 1, 2014 | 04:09 PM
Car: 1987 IROC - Z
Engine: 5.0 TPI
Im thinking that maybe there is a sensor that is sending voltage through a ground, so I may unplug every sensor one by one until I find the one that brings the voltage to pin d11 back to 0v
Pac J
May 17, 2020 10:44 AM
Bubbajones_ya
Oct 25, 2015 08:01 PM
wanext
Oct 6, 2015 12:18 AM
bjpotter
Oct 4, 2015 07:48 PM
sjorgens
Oct 1, 2015 07:54 PM
