Little help with these connectors?? Pic inside
Old May 2, 2014 | 07:31 PM
seiplentz's Avatar
Car: 85 Z28
Engine: GMPP 350 HSR
Axle/Gears: 4th gen 3.42 Posi LS1
I believe I am right with these wires but just want to make sure.
Little grey connector Pink- Power
Pink/Blk Ign Power
Brown Cooling fan relay from HVAC controls
On the Black connectors I only need a few wires here.
Red/Blk Fuel Pump?? If I apply power here will it energize the pump?
Purple- Power for TCC solenoid that goes through the brake switch?
Tan/Blk TCC ground???
To wire back up the TCC would I connect the Purple and Tan/Blk to those connectors and then use the dark green as a ground trigger? Or just connect the purple and use the Tan/blk and ground that?
Sorry for all questions I am almost done my commander 950 install
Old May 2, 2014 | 08:45 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: Little help with these connectors?? Pic inside
TCCi s controlled by tan / blk to ground , the 3rd wire is a 4th gear input to the ECM
Old May 4, 2014 | 08:32 AM
seiplentz's Avatar
Car: 85 Z28
Thank You.. Now to confirm the rest..
Frozer!!!
Jan 19, 2024 04:55 PM
GTAman
Mar 15, 2019 11:40 AM
3.8TransAM
Sep 3, 2015 06:38 PM
Thirdgen89GTA
Aug 20, 2015 03:11 PM
Thirdgen89GTA
Aug 20, 2015 12:11 PM
