Sensor Identification please
Old May 12, 2014 | 06:24 PM
techno101's Avatar
Car: 1989 Camaro RS
Engine: Modified 350 TPI
Transmission: Modified 700 R4
Axle/Gears: Posi 3.42
So on an 89 camaro, the fuel pump relay is on the drivers side firewall. What is the relay directly to the left of it called?? On a TBI car the spark module is located right behind this sensor, thanks
Old May 12, 2014 | 06:56 PM
Stauf's Avatar
Car: 91 Z28 Coupe
Re: Sensor Identification please
If you are describing it right, that should be the cooling fan relay
Old May 12, 2014 | 07:09 PM
techno101's Avatar
Car: 1989 Camaro RS
So why does the fan cut off when the fuel pump relay is unplugged?
Old May 12, 2014 | 09:05 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Connectors swapped?
What colors are the wires on each ?
Old May 12, 2014 | 09:12 PM
Stauf's Avatar
Car: 91 Z28 Coupe
Old May 13, 2014 | 06:46 AM
techno101's Avatar
Car: 1989 Camaro RS
One sensor has 5 wires one has 4 wires. They're not swapped
Old May 13, 2014 | 08:52 AM
hrspwr's Avatar
Car: 86 IROC
Engine: 350 Vortec TPI
Axle/Gears: BW 3.27
Unplug the other relay and what happens?
Old May 13, 2014 | 08:54 AM
techno101's Avatar
Car: 1989 Camaro RS
Nothing happens differently. It I unplug the fuel pump relay, the pump primes fine, car starts fine. If the fuel pump relay is plugged in, the fuse by the battery blows.
Old May 14, 2014 | 11:51 AM
ploegi's Avatar
Car: 1988 Pontiac Firebird Formula
Engine: 5.7 TPI
Then you have the wrong relay. There is no way for the ECM to provide power to the pump, without that relay.
Old May 14, 2014 | 03:13 PM
techno101's Avatar
Car: 1989 Camaro RS
It's worked fine for years with that relay
Old May 14, 2014 | 03:14 PM
techno101's Avatar
Car: 1989 Camaro RS
And the fuse blows only after the car is warmed up
Old May 14, 2014 | 06:22 PM
MoJoe's Avatar
Car: 87 IROC
Engine: L31 350
Axle/Gears: 4.10 D44
Do you have the fuel pump and fan connectors reversed at the relays? It fits the problem you are describing... Car gets hot, fan turns on and blows the fuse.
HoosierinWA
Oct 7, 2015 10:15 AM
aaron7
Sep 30, 2015 09:15 AM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
dusterbd
Sep 29, 2015 08:40 AM
SS-EXPRESS
Sep 28, 2015 09:14 AM
