FUEL PUMP AND TANK HELP!
Old May 15, 2014 | 09:53 PM
z28_5.7_TPI's Avatar
Car: 92 Z28 25TH ANN. CAMARO
Engine: 5.7 350
So just got my injectors from South Bay and I am going to re do my whole fuel system, my question now is what tank and fuel pump are the best to go with? I wanted to do walbro but I've heard about people saying there is some Chinese knock offs and there pretty much out there already. . And tank will any tank do what's the pros and cons from an autozone tank or a tank that cost more $$$ online from a better manufacturer?
Old May 20, 2014 | 07:17 AM
rusty vango's Avatar
Car: 86 IROC
Engine: 5.0 TPI
Transmission: 700-R-4
Axle/Gears: 2.73 open
Re: FUEL PUMP AND TANK HELP!
as far as tanks are concerned,youre better off with a OEM one.too many people having the "spectra" headache.im running a fuel pump from NAPA 5 years and no problems.the trick is to not run ethanol garbage gas. I run 100%gas .with the occasional shot of 110 octane AVGAS.
Old May 20, 2014 | 11:40 AM
Camaro_383's Avatar
Car: 92 25th Anniversary RS
Engine: 5.0 TBI 305
Get the tank from the dealer to make sure it is built and shaped correctly. As for the pump and other parts, get them from more higher up stores if you're not looking for a specific brand. Yes, it may cost more but they will be good parts to replace without having to worry about them breaking two weeks later.
Grant2k
Jul 10, 2018 04:01 PM
theshackle
Mar 5, 2017 06:37 PM
beachrodder
Aug 25, 2015 08:05 AM
AkDrifted
Aug 17, 2015 07:45 PM
Kaweh
Aug 9, 2015 02:54 PM
