cant get my 87 to fire. put in new fuel pump and relay
Old Jun 5, 2014 | 04:51 PM
bucs_gators_fan's Avatar
Car: 1982 Camaro converted into an 87
Engine: 5.7 TPI
Transmission: Manual
cannot get my 1987 Camaro to run. one day I jumped in to leave, turned the key, just kept cranking. So then I replaced the fuel pump. still nothing. I even put in a new fuel pump relay and wire harness. still nothing. when I use a jumper wire on the harness, the pump kicks on. when I go to start it the car will start then shut right off. I take away the jumper wire and its back to doing nothing. I have no idea what else to to. I even put in a esc module today hoping that was the problem. still nothing. my car has a 5.7 tpi. any help would be greatly appreciated .
Old Jun 5, 2014 | 05:09 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: cant get my 87 to fire. put in new fuel pump and relay
Originally Posted by bucs_gators_fan
cannot get my 1987 Camaro to run. .
Why are you starting a NEW thread about your problem when you haven't followed through on the old one ?
Answers are still going to the same
https://www.thirdgen.org/forums/elec...reen-wire.html
Old Jun 5, 2014 | 07:15 PM
Engine: 5.7 TPI
I started new threads so I can find someone that has had the same problem. I just want this problem fixed. I cant delete my old thread. I found out where the green and white wire lead to. im not sure that is what my problem is. these new threads describes mmy problem better. that's why I started NEW threads
Old Jun 6, 2014 | 07:39 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
when I go to start it the car will start then shut right off..
Would suggest a injector ( not pulsing ) problem
Get a noid light and check for injector pulse
Old Jun 6, 2014 | 09:03 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Without looking at the other thread, you need to start with the basics, (guessing OZ mentioned in the other post) but do you have spark? Do you have fuel pressure?
It's just my opinion, based on the parts you've tossed in, plus time (hope you did it yourself) you could have bought some nice diag tools to help you out.
Old Jun 7, 2014 | 07:51 PM
Engine: 5.7 TPI
I just tried the beat on the ecm method and the pump kicked on, so I started the car, it ran for a little while and died again. so does this mean the ecm is bad then?
Old Jun 8, 2014 | 12:56 PM
rusty vango's Avatar
Car: 86 IROC
Engine: 5.0 TPI
Transmission: 700-R-4
Axle/Gears: 2.73 open
dude, check your codes. it alone can solve your problem by pointing you in the right direction. I understand,believe me . sometimes I resort to throwing $100s at mine in the hopes of uncovering something I missed. but start with the CEL and see what codes you may have.and I might add .resist the temptation to go to auto zone for the cheapest parts you can get. and if you are unlucky enough to need a MAF. I strongly suggest a NEW one .I got mine from o,reilleys .made by a co. named "rich porter". and it cost $450.and as for the two relays that run it. call your chevy dealer and get the part numbers for the particular year you built your car from. then you can be sure to get the PROPER relays. take a deep breath, and start over. let us know what you find out
Old Jun 9, 2014 | 05:23 PM
Engine: 5.7 TPI
I got a ecm from the junkyard and the car fired and ran great. im going to have one of my buddies who is a mechanic take apart the old ecm and see if some of the solder came off on the board. a guy on here gave me that tip to see if there was anything like that wrong with it.
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
mustangman65_79
Apr 14, 2017 05:37 PM
92camaroJoe
Aug 13, 2015 06:07 AM
Kaweh
Aug 9, 2015 02:54 PM
