Throttle sticking.
Old Jun 18, 2014 | 10:39 PM
Wesotsuki's Avatar
Car: 89' Iroc Z
Engine: LB9
Transmission: 5 speed manual - warner gear
Throttle sticking.
When engine is running, the throttle will stick a bit, causing it to rev and maintain that rpm. However, when the engine is off, it does not get stuck, at all.
I've changed the cable, throttle body is brand new. Pedal is not getting stuck by the rug.
Any thoughts?
Old Jun 20, 2014 | 10:27 PM
1MeanZ's Avatar
Car: 86 IROC
Engine: 383
Transmission: TKO 600
Axle/Gears: 3.54 Dana 44 IRS
Re: Throttle sticking.
I just had this problem with a professional products TB. Best I could tell was that the throttle shaft was deflecting under the vacuum load of the engine and there wasn't enough clearance in the body to allow the throttle shaft to turn freely. After I messed with mine some more it started squeaking and sticking with the engine off. Summit racing is being cool and taking it back.
Old Jun 21, 2014 | 01:23 AM
Wesotsuki's Avatar
Car: 89' Iroc Z
Engine: LB9
Oh wow, I got mine from summit as well. 52mm TB? Cause the last TB I had was also sticking, not sure if it was OEM or not. But it was the same issue with my old as well.
Old Jun 23, 2014 | 11:34 AM
1MeanZ's Avatar
Car: 86 IROC
Engine: 383
it was a professional products 58mm unit. It moved freely in the box, with the engine running, it would stick at any and every position. I think its just a junk part, I got what I paid for.
I have a stock throttle body on the car that sticks as well, but it only sticks right down near the fully closed position. The throttle shaft is a bit worn and moves around in the throttle body casting more than it should, I think the engine sucks the throttle butterflies back and puts the throttle butterfiles in a bind in the bore causing an intermitten high idle. When it's idling high I can pop the hood and push the throttle back with my thumb and it idles right down.
Old Jun 23, 2014 | 05:34 PM
Wesotsuki's Avatar
Car: 89' Iroc Z
Engine: LB9
Yeah I've been experiencing the same exact thing, it's quite irritating, and solution on how to resolve it??
Old Jun 25, 2014 | 11:12 AM
1MeanZ's Avatar
Car: 86 IROC
Engine: 383
only options are to have the stock throttle body rebushed, or spend the money and buy a decent aftermarket unit from BBK, or Holley.
Old Aug 7, 2014 | 02:32 PM
MrPackstin's Avatar
Car: 1989 GTA
Engine: 5.7 w/Paxton
Summit 58mm 227707 Sticking Throttle
Add another Summit 58mm 227707 to the list.
Old Aug 7, 2014 | 02:50 PM
formula forever's Avatar
Car: 91 formula
Engine: 350 tuned port. bolt ons
I had the same issue last year. my factory stock 48mm throttle body was sticking and on the highway it would stick I replaced it with a holley 52mm throttle body. and what's really crazy was I had a defective throttle body sent to me but holley replaced it for me and gave me another one. all is well now. If you want to keep the car stock you can have it rebuilt or if you don't mind aftermarket. go with BBK or holley. The holley looks the best of all the throttle bodys.
Linson
Oct 24, 2025 02:00 PM
Pac J
May 17, 2020 10:44 AM
Z28/ZR1
Oct 23, 2015 01:04 PM
armybyrd
Carburetors
Oct 20, 2015 03:57 AM
HoosierinWA
Oct 7, 2015 10:15 AM
