I did the large cap HEI ditributor swap, should the bypass wire be hooked up?
Old Jun 20, 2014 | 05:34 PM
yellowsnow's Avatar
So I swapped in a large cap HEI distributor on the TBI engine using this diagram https://www.thirdgen.org/forums/atta...ion-wiring.jpg
Found on this thread https://www.thirdgen.org/forums/tbi/...p-hei-tbi.html
So it worked and I drove it a few miles and got the timing where I wanted it. Then I shut it off and it wouldn't fire again. (who knows what really caused this, but..)
I don't remember if I had the bypass wire hooked up or not. Then I got it in my head that somehow I burned out the stock ICM by hooking up the bypass wire.. So I bought a new one and am now scared to hook up the bypass wire. I have some kind of little problem going on, MAP sensor or fuel filter. But I have been wondering about the bypass wire. Can I hook it up without hurting the ICM?
Sorry meant to put this in TBI
Old Jun 22, 2014 | 11:25 AM
darbysan's Avatar
Car: 1985 El Camino Choo Choo
Engine: L31 Crate 350 w/ TPI
Transmission: GN 200-4r
Axle/Gears: GN 8.5 3.73
Re: I did the large cap HEI ditributor swap, should the bypass wire be hooked up?
I have the large HEI on my TPI setup, with the by-pass wire hooked up ( if you mean the brown wire with the connector, that you unplug for setting timing). Been running for years that way.
1992 Trans Am
May 10, 2023 07:19 PM
midge54
Dec 27, 2019 04:14 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
stalkier
Aug 7, 2015 04:49 AM
