smog pump delete
Old Jul 2, 2014 | 03:25 PM
happyhapka's Avatar
Car: 1986 Trans AM WS6
Engine: 383 Vortec TPI, PUTS SMILES ON FACE
Transmission: PATC LVL 3 Raptor Transmission
Axle/Gears: 3.27 POSI 9 BOLT
smog pump delete
So what is the simplest way of blanking off the inlets on the manifolds? just a bolt in each hole?
I've heard of people crimping the tubes but would rather bolt the but do not know the size.
Old Jul 2, 2014 | 11:10 PM
billyhoss's Avatar
Re: smog pump delete
I just cut them as close as I could and spot welded them but I have headers so not sure if its different for stock
Old Jul 3, 2014 | 12:03 AM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
I'd always assumed they were a pipe plug thread..1/4 NPT?
But been years since I looked.
Old Jul 3, 2014 | 03:03 AM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
You mean decades....
I don't know if they came stock like this or not, but back when AIR was introduced in the mid-1960's I used to see some medium duty trucks without the AIR system and the AIR injection holes in the manifolds were capped with brass pipe plugs.
Old Jul 3, 2014 | 08:43 AM
happyhapka's Avatar
Old Jul 3, 2014 | 10:01 AM
mmadden55's Avatar
Car: 86 Firebird
Engine: 305 SBC
Transmission: 700 R4 TCI
1/4,pipe plugs available at Hardware stores.
The bitches are hard to get out since they are usually rusted in solid. I puled the manifold off the car, cut the tubes off flush to the nut, WD 40 the p*** out of it, and used an impact wrench.
Old Jul 4, 2014 | 02:33 PM
ploegi's Avatar
Car: 1988 Pontiac Firebird Formula
Engine: 5.7 TPI
PB Blaster is FAR superior to WD-40.
Whats really funny is, the BEST penetrating lubricant/rust dissolver is a 50/50 mix of acetone, and auto trans fluid. Both of which are cheaply available in the auto section at wal-mart....
Frozer!!!
Jan 19, 2024 04:55 PM
italiano67
Dec 11, 2016 09:21 AM
LittleFranks
Sep 17, 2015 12:22 PM
BlackphantomZ28
Aug 21, 2015 07:12 PM
actionj
Carburetors
Aug 16, 2015 09:51 AM
