1991 5.7 TPI runs great when engine is cold, but not after it warms up
Old Jul 15, 2014 | 08:50 PM
projectZ281LE's Avatar
Hello I hope I can get some much needed help. I rescued a 1991 Z28 1LE from a parking lot in the Bronks. Hadn't been started for 5 years. Brought it back to Kansas. Replaced the ignition and key and pumped out the old gas and put in some fresh. Started up after 4 tries . However ran not so hot. After some diagnostic troubleshooting I discovered that the distributor needed overhauled and some vacuum lines where bad. Fixed and then for giggles replaced the fuel filter. Then I said whey not replace the spark plugs. Done. Checked the wires they looked like new. At this point the car starts good and runs nice. However when it gets to the operating temp it runs sluggish. But when the engine is cool it will leave a nice . It's running on all 8 and no service light. So I said why not replace to O2. Still no change. But what is funny is after I fixed the air conditioning I noticed that when the engine was cold it would blow ice cold air. But like the throttle response it too doesn't work right when the engine warms up. The only things that I have not replaced is the egr and the egr selonoid. I believe the issue is that or maybe the 23 old injectors??? Car does not overheat. I have not checked for codes, but I know I'm not far away. Please help!
Old Jul 16, 2014 | 05:57 PM
chevypower91's Avatar
Car: 1991 Camaro Z28
Engine: 305 cid
Transmission: 5 speed
Axle/Gears: Posi/3:42
Good job on saving the car.
Have you tested your injectors to see if they performing well? They could be the originals and those multi-techs do not last long.
Old Jul 16, 2014 | 05:58 PM
Engine: 305 cid
Good job on saving the car. Have you tested your injectors to see if they performing well? They could be the originals and those multi-techs do not last long.
Old Jul 17, 2014 | 03:15 PM
IROCU2's Avatar
Car: 1987 IROC-Z
Engine: 5.7 TPI
Transmission: 700-R4
Re: 1991 5.7 TPI runs great when engine is cold, but not after it warms up
Have you tried to pull any DTC codes? This is where I would start from.
Frozer!!!
Jan 19, 2024 04:55 PM
jhawkeye
May 25, 2022 06:33 PM
justin57
Aug 20, 2015 07:05 PM
jharrison5
Aug 19, 2015 05:53 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
