What valve springs for roller cam cars?
Car: 1989 IROC
Axle/Gears: 3:23 Torsen 4th gen rear
I would like to get a set of 180cc heads and there are a lot to choose from out there. But what about us L98 guys that have roller tappets, we need different springs right?
How do I know what are the correct spring pressures for my application? Does one just buy a bare set of heads that say up to 1986 years only and install higher pressure springs for a roller application?
I'm really trying to figure out what the best method is here.
Thanks!
Thanks!
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Re: What valve springs for roller cam cars?
Stock rollers look for single spring heads with around 100-115 lbs seat pressure and 300 open. That should hold stock cams
Mild performance cams, double springs around 120-135 lbs seat pressure typically work with 320-350 lbs open pressure.
Aggressive lobe rollers, may want double springs in the 145-155 seat range, 360-400 open.
Heavy valve race setups or very agressive race lobe forced induction cars turning ultra high rpm, 175-200 lbs seat, 450-500 open, and aftermarket lifters that can handle the loads like Morels
These are rough guidelines. Rpms, valvetrain mass, pushrod size/type, etc need to be reviewed.
Car: 1989 IROC
Orr89 you're the man, always the first to come through with helpful information!
As far as spring diameter stock is like 1.25 isn't it?
Car: 86 IROC
Engine: 5.0 TPI
Transmission: 700-R-4
Axle/Gears: 2.73 open
I would like to add this, stock roller lifters do not like really strong springs. they tend to self destruct when you go big.
84z96L31vortec
Aug 20, 2017 12:16 AM
84z96L31vortec
Aug 10, 2015 08:27 PM
