Bypass hose
Old Jul 25, 2014 | 09:00 AM
lakeport's Avatar
Car: 1988 GTA Trans AM
Transmission: 5 speed
Bypass hose
I need to replace the hose from the front of manifold to the heater core, my diverter valve has been removed, i currently have 2 hoses that are joined, I am fine with replacing as one single hose or replace with 2 separate, just not sure what hose to order from rock auto to replace from front of intake to where the diverter once was, what size, length
all help appreciated
Old Jul 25, 2014 | 09:28 AM
Bob88GTA's Avatar
Car: 88GTA
Engine: 5.7TPI
Re: Bypass hose
Lakeport....See this post. Pictures and all.
https://www.thirdgen.org/forums/cool...r+hose+routing
You will need to go and buy (or not) the diverter valve. Then use cut to fit heater hose
Old Jul 25, 2014 | 11:07 AM
lakeport's Avatar
Re: Bypass hose
many thanks for that, does anyone know of a hose that can be purchased that will run from firewall to front of TB, and part number if possible
or just a hose to run from front of TB to where the diverter was, as my current hose from front of TB connects to another hose where diverter was, if no part numbers what is the diameter of the hose from the front of TB?
Is it 5/8"?
Old Jul 25, 2014 | 11:15 AM
Bob88GTA's Avatar
Car: 88GTA
Engine: 5.7TPI
Re: Bypass hose
Is it 5/8"?
YES, 5/8" Go to Rockauto.com they have all the premolded hoses you are looking for.
Old Jul 29, 2014 | 02:32 PM
lakeport's Avatar
Re: Bypass hose
so i am trying to get all the correct hoses and the diverter valve ordered and reinstalled, having some trouble on locating the correct hoses
does anyone know the part numbers for the hoses i should order from rockauto to get this put back together
$750 L98
Feb 1, 2025 02:25 PM
Pac J
May 17, 2020 10:44 AM
sheachopper
Jul 31, 2019 11:27 AM
skinny z
Carburetors
Sep 29, 2015 11:25 PM
Formula8r89
Sep 22, 2015 04:24 PM
