Is this normal?
Old Aug 10, 2014 | 02:26 AM
Chiknhawk's Avatar
Is this normal?
I have a 91 z with a 5.0 TPI. It has 70k miles. I recently performed a smog delete, EGR delete, added headers with an off road y pipe(no cats), added a shift kit and 373 gears. My question is this, I have not had any check engine light or any known issues. Should I and is this normal? Do I still need to get a chip burned or can I run it the way it is? Thanks in advance.
Old Aug 10, 2014 | 11:17 AM
BadSS's Avatar
Re: Is this normal?
It would run better with a custom tune, but back in the day all we could do was set base timing and install an adjustable fuel pressure regulator and they ran decent without a chip. If you're not setting an EGR code, it's probably because you haven't met the criteria needed to set the code. I know when I was running the stock chip as long as I was driving around town and only had short highway drives it wouldn't set - the only time it would set was when I ran a number of miles on the highway with the cruise.
Fanatic1074
Oct 3, 2022 05:57 AM
Linson
Oct 1, 2015 09:50 PM
dusterbd
Sep 29, 2015 08:40 AM
BWilcox
Sep 20, 2015 12:19 PM
Stroopwafel
Sep 11, 2015 06:38 AM
