LG4 to TPI
Car: 92 Trans Am, 87 Formula
Engine: 305 soon to be TBI, 91 305 TPI swap
Axle/Gears: 10 bolt
LG4 to TPI
so im getting a 91 TPI engine given to me. i have most of my bases covered. Accessory drive, wire harness, engine, computer, transmission, exhaust, heck i even have a fuel pump and sending unit. Will i need a tank and fuel lines as well?
Car: 86 IROC
Engine: 5.0 TPI
Transmission: 700-R-4
Axle/Gears: 2.73 open
Re: LG4 to TPI
the tanks the same ,but the sending unit isn't. and yeah ,youll need the fuel lines off a TPI car. or fab some up.
Axle/Gears: 10 bolt
Re: LG4 to TPI
ok good. fuel lines i can deal with. its going to be a pain but not too bad, already have a sending unit so im not too worried about it
Car: 1986 Camaro SC
Engine: 305 TPI Procharged D1SC
Transmission: Tremec TKO-600
Axle/Gears: Moser 12 Bolt 3.73 posi
Re: LG4 to TPI
i've done this swap, it's easy to just use the TPI fuel lines, everything will just bolt together that way.
Axle/Gears: 10 bolt
Re: LG4 to TPI
i'll have to put new fuel lines in it. the car that the motor is from is using a LT1 from a wreck car so he's using his fuel lines.
Sanjay
Aug 12, 2015 03:41 PM
