Removed engine, re-fitted and now atarts poorly and dies if not revved
Old Sep 16, 2014 | 01:01 PM
214jay's Avatar
Car: 1989 Pontiac Firebird Formula 350
Hello
I have an 89 Firebird 350TPI. I have recently re-fitted the engine which has been out of the car for 1.5yrs. Everything has been connected and the engine turns over with starter motor (sounds like it is struggling half of the time), it will eventually fire up but die immediately. If I slightly press the accelerator pedal the engine will stay revving and sound lovely but as soon as I release the throttle it dies again.
The engine service light is on but reading no fault codes (just flashed code 12 constantly). I do not have an exhaust on at the moment, only hedman hedders with the exhaust sensor modified into the lower end.
Smog/Aircon has been deleted, otherwise standard.
Has anyone any ideas?
Many thanks
Jay
Old Sep 16, 2014 | 08:45 PM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
Engine: 383 TPI Procharger D1SC
Transmission: TKO600
Axle/Gears: Strange S60 3.73
Re: Removed engine, re-fitted and now atarts poorly and dies if not revved
What is your base timing set at with the est wire disconnected? Make sure that the firing order is set correctly too.
Frozer!!!
Jan 19, 2024 04:55 PM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
db057
Aug 22, 2015 08:17 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
3rdgenparts
Aug 8, 2015 07:09 PM
