edelbrock intake manifold and runners questions
Old Sep 19, 2014 | 05:29 PM
earlpote's Avatar
hello, i recently received my edelbrock manifold and runners and have a couple questions.
what are these holes? it is not located on the stock manifold. i do not have instructions and i tried searching for it with no luck. i also have these that look like they match it but i dont know where they go:
also is there a reason one of the runners is missing a hole?
heres the other one:
thank you
Old Sep 19, 2014 | 06:45 PM
aliceempire's Avatar
Transmission: T-5, TH350, T-5
Re: edelbrock intake manifold and runners questions
That looks to be a vortec head style manifold. The port closest to the center of the manifold is for the egr. The pipe covered in heat wrap is the pipe that goes from it to the exhaust manifold/header.
The port closest to the distributor I believe is for coolant, I very well could be wrong. I think it's a corvette used port.
I don't know what the extra pipe is for. Best guess is its the one that is supposed to go into the exhaust manifold itself.
The runner with the hole is for your egr to function. The other one is blocked off because its a set for the later tpi without a cold start injector.
Old Sep 19, 2014 | 07:05 PM
cuisinartvette's Avatar
Car: 67 ******mobile
Engine: 385 Solid roller
Axle/Gears: 4.11
x2 steam hole on C4s. THey had aline that ran from the PS exh manifold to the fitting there on the intake.
Sure like that coating they use
Old Sep 19, 2014 | 07:23 PM
That's what I thought but I try not to put misinformation out there.
Old Sep 19, 2014 | 07:53 PM
earlpote's Avatar
so i need to block off the 2 holes my fingers are pointing to, since theyre a corvette used part?
Old Sep 19, 2014 | 08:06 PM
If you are going to retain your egr using vortec heads you will need to use that exhaust manifold to egr port. If not then block it off but the egr will need to be deleted in the computer.
The coolant port you can block it off or use it to bleed air out of your coolant system.
Old Sep 19, 2014 | 09:25 PM
earlpote's Avatar
isnt the EGR the one thats directly in the center of the intake manifold?
Old Sep 19, 2014 | 09:57 PM
There is no exhaust cross over on vortec and aluminum heads. The exhaust has to come from somewhere, therefore the exhaust manifold is elected.
Old Sep 19, 2014 | 11:17 PM
earlpote's Avatar
ok, i just figured out what happened. this was originally supposed to be installed with vortec heads that my uncle had previously bought (car used to be my uncles) and it didnt come with any paperwork or anything. so i took off the stock manifold for no reason cause this obviously doesnt fit stock heads...
so, since ive got the stock one off, what kind of performance baseplate can i buy to fit the stock heads? these?
http://www.ebay.com/itm/Edelbrock-High-Flo-TPI-Base-Plate-3860-/390930880001?pt=Motors_Car_Truck_Parts_Accessories&hash=item5b054bd601&vxp=mtr
Old Sep 20, 2014 | 09:27 AM
That will fit stock heads. All the same ports the vortec plate has will be there on this plate too. You can simply block off that egr port and use the normal fbody egr passages.
Zeek1041
Theoretical and Street Racing
Aug 21, 2015 08:45 PM
theurge
Aug 21, 2015 12:46 PM
86IROC112
Aug 17, 2015 02:00 PM
Jake_92RS
Aug 11, 2015 10:39 AM
