92 camaro z28 please help
Old Oct 19, 2014 | 08:32 AM
onefreakz's Avatar
Car: 92 camaro z28
Engine: 5.7 tpi
Axle/Gears: G92 3:23
hello fellow thirdgeners , i just bought a 92 z28 5.7 been sitting since 2006 in storage , does have new oem fuel pump, new reman southbay injectors, new fpr, cap&rotor, icm, new spark plugs and wires, new oem ecu, car starts up but idles/runs rough car shakes runs rich also seems like theirs no ignition cuz smells like raw gas ,i notice it does have a minor exhaust leak on passenger side manifold gasket, i hooked up a scanner yesterday and this what it shows, i never seen this before. this point im lost ive searched and couldnt find anything please help..thanks
Old Oct 19, 2014 | 01:14 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
Re: 92 camaro z28 please help
Sitting for eight years.....
  1. You replaced a lot of stuff but there's no mention of draining and cleaning out all the old fuel in the tank.
  2. Is the CEL on?
Old Oct 19, 2014 | 02:31 PM
onefreakz's Avatar
Car: 92 camaro z28
Engine: 5.7 tpi
Ya forgot to mention replaced fuel tank with a better one flushed out tank, old one had rust inside , also new sending unit ..no check engine as of now , but before i replace the ecu it did have a code 42 and 32 along with whats in the picture,no codes so far, ive driven 10 miles with new ecu installed , hooked up the scanner only thing that came up is whats posted in picture
Old Oct 19, 2014 | 03:04 PM
southbay08's Avatar
might want to check your fuel pressure regulator as well. Sometimes the diaphragm tends to dry out and crack
Old Oct 19, 2014 | 03:07 PM
onefreakz's Avatar
Car: 92 camaro z28
Engine: 5.7 tpi
Ya fpr is also new
Old Oct 23, 2014 | 10:33 PM
onefreakz's Avatar
Car: 92 camaro z28
Engine: 5.7 tpi
UPDATE...hello everyone i found a broken valve spring on cylinder 4 exhaust side , where can i buy new oem valve springs ,should i avoid local parts store or should i buy performance springs for stock engine , recommendation with part # will be appreciated ..now my other question will broken valve spring cause the issue on the pic shown above?
Frozer!!!
Jan 19, 2024 04:55 PM
CarGuyDennis
137
Dec 6, 2016 11:02 PM
GVMV
Aug 16, 2015 08:01 PM
GVMV
Exterior Parts for Sale
Aug 16, 2015 07:08 PM
greeny
Wheels and Tires
Aug 12, 2015 03:55 PM
