stalls sometimes
Old Dec 7, 2014 | 09:48 AM
greenyone's Avatar
Car: 91 G92 Z28
Axle/Gears: 342
stalls sometimes
91 LB9 G92 5spd. Just rebuilt block and heads. Smog, EGR elimintated and prom reflashed to compensate. Sometimes when I push in the clutch to come to a stop it falls on it's face. I've replaced everything in this car. New IAC, TPS, O2, CTS, cam, lifters, timing chain, dizzy and module etc... I even tried swapping back to the old IAC and TPS sensors and get the same intermittent result. Timing set to spec, TPS volts are spot on and no dummy lights other than a faulty vehicle speed sensor. I wouldnt guess a bad VSS to cause a stall condition though. Not sure what else to look at. Any ideas?
Old Dec 7, 2014 | 10:47 AM
fireburdluvr85's Avatar
Car: 91 formula ws6
Engine: 355 tpi OBDII
Transmission: 4l60E
Axle/Gears: 2.73 with 4th gen brakes
Vss helps decide engine load. If it doesn't work correctly the fueling/timing will be off at any given time. Fix that first and then come back.
darwinprice
17
Oct 11, 2015 11:51 PM
HoosierinWA
Oct 7, 2015 10:15 AM
Jlanz55
Sep 29, 2015 08:55 AM
lanceflame44
Sep 25, 2015 12:28 PM
amcnellis
Sep 16, 2015 04:16 PM
