Stealth Ram Help!!!
Old Dec 16, 2014 | 11:35 AM
Red_1989_GTA's Avatar
Car: 1989 Trans Am GTA
Stealth Ram Help!!!
I have 350 TPI with dart iron eagle heads.
Intake Valve Diameter
2.020 in.
Exhaust Valve Diameter
1.600 in.
Intake Runner Volume
165cc
Exhaust Runner Volume
65cc
I want to get the Stealth ram intake. I will be getting a new cam (XR276HR).
How much of a gain can I expect? Do I have to get a new wiring harness and ecu? What size injectors should I use with the stealth ram? How easy/hard is the installation? Whats the RPM range with the stealth ram?
Old Dec 16, 2014 | 03:00 PM
Thirdgen89GTA's Avatar
Transmission: M28 T56
Re: Stealth Ram Help!!!
2.020 in.
1.600 in.
165cc
65cc
You have a lot of reading to do. Start searching up the StealthRam install threads.
90% of your answers are going to be there.
You do not need a different harness if you have a TPI car. You will need odds and ends for fuel lines, vacuum fittings and other such items.
Linson
Oct 24, 2025 02:00 PM
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
L98GTA87
Oct 19, 2015 10:43 PM
mfp189
Sep 27, 2015 09:25 AM
R3500
Sep 8, 2015 10:12 PM
