305 swap to 350
Old Dec 26, 2014 | 01:20 PM
mrfixit628's Avatar
305 swap to 350
we have a 58 impala that had 305 tune port injection on a older 305, we took out the 305 and replaced with a stock 350 motor but i believe the heads are 72cc chambers. Motor runs great at an idle but wants to break up at acceleration like a miss. we did not change the ecm due to its not a factory one, some company called air soft tech. the injectors have been replaced to 26lb.
Old Dec 29, 2014 | 10:28 AM
darbysan's Avatar
Car: 1985 El Camino Choo Choo
Engine: L31 Crate 350 w/ TPI
Transmission: GN 200-4r
Axle/Gears: GN 8.5 3.73
Re: 305 swap to 350
you will need an ECM tune to account for the larger displacement and the bigger injectors.
Old Dec 29, 2014 | 02:25 PM
mrfixit628's Avatar
Re: 305 swap to 350
what is a good fuel pressure to run its a 38lbs with vacumn on. For computers how is the fast zx self tuning system?
Old Dec 30, 2014 | 07:28 AM
86iroct5's Avatar
Car: 86 iroc, 02 v6 camaro
Engine: 350 HSR, 3800 V6
Transmission: T56, WCT5
Axle/Gears: 9in 4.11 posi, 3.23 LSD
Re: 305 swap to 350
just go out and get the proper prom for the 350 from the junk yard...
Old Dec 30, 2014 | 09:46 AM
mrfixit628's Avatar
Re: 305 swap to 350
wish the car had a stock ecm, the car has some aftermarket system on it from the late 80s or early 90s going to have to replace entire system. the system is called air sensor technology its nice for a 305 but not the 350.
Old Dec 30, 2014 | 10:20 AM
darbysan's Avatar
Re: 305 swap to 350
Just for curiosity, I googled air Sensor Tech and came up with an instruction manual. Maybe this can help? Looks like it was designed for a TBI system ( not TPI), although it should be able to be modified for use on a TPI.
http://www.bdub.net/manuals/AirSenso...aintenance.pdf
Old Jan 5, 2015 | 10:37 AM
mrfixit628's Avatar
Re: 305 swap to 350
is anybody familiar with a computer system called fast ez self tuning? its at summit part number 302000
xkingcodex
Feb 12, 2020 07:43 PM
Jake_92RS
Jan 28, 2020 10:37 PM
theshackle
Mar 5, 2017 06:37 PM
st.evel07
Aug 13, 2015 06:15 PM
Sanjay
Aug 12, 2015 03:41 PM
