mechanical water temp gauge
Old Dec 27, 2014 | 10:58 AM
Kameron85's Avatar
I have an 85 iroc with the tpi. Been having problems with the temperature gauge not always working so I bought a mechical gauge but idk where to connect it at. Am I supposed to take out the collant temp sensor or something? Please help.
Old Dec 27, 2014 | 02:24 PM
92RS_Ttop's Avatar
Car: 1992 Camaro RS
Engine: Rebuilt 350 going in after paint
Transmission: WCT5, 7k & counting behind the 350
Axle/Gears: 4thgen disc rear w/ 3.73 Posi
Re: mechanical water temp gauge
Each cylinder head will have a port on the sides, just above the line of the spark plugs. One side will have a temp sensor already there, the other side should just have a plug in it. Unscrew the plug and screw your new sensor in. The plug on my heads took the square end of a ratchet. It was EXTREMELY tight after all these years, so work carefully to avoid stripping the threads. And use some Teflon pipe tape to seal the threads on the new sensor.
Old Dec 28, 2014 | 02:09 PM
Kameron85's Avatar
I looked for what you mentioned and I cannot seem to find it. What motor do you have maybe the layout is different. Do you have any idea If I could drill and tap a hole into the thermostat housing to fit it?
Old Dec 31, 2014 | 01:45 AM
n2deep22's Avatar
gonna have to remove the temperature sending unit on driverside head between #1-3 cylinder.https://www.thirdgen.org/forums/cool...re-sensor.html . post #18
Old Dec 31, 2014 | 08:09 AM
92RS_Ttop's Avatar
Car: 1992 Camaro RS
I have a fairly stock 350, a 70's block with 80's 305 heads. Each head has a plug in the water jacket. One head is still plugged. The other has my fan switch installed. I do not have the original temp sensor installed for the ECM since I am running a Holley carb and no ECM. There is another port in the coolant passage on my intake manifold, and I have the probe for my mechanical temp gauge installed there.
Old Jan 3, 2015 | 02:10 PM
Kameron85's Avatar
I changed the coolant temp sensor about 2 weeks ago because I thought that would fix the gauge so what your saying is I can remove it and plug the mechanical gauge directly into that, spot?
angel2794
Sep 8, 2015 06:22 PM
jtwoods4
Sep 3, 2015 05:39 PM
Jote4805
Aug 25, 2015 06:11 PM
R3500
Aug 17, 2015 12:16 PM
