GTA 5.7 injectors
Old Dec 31, 2014 | 03:21 PM
UKPROCHARGEDGTA's Avatar
Car: 1989 Trans Am GTA
Engine: Procharged 350tpi
Transmission: uprated 700R4
GTA 5.7 injectors
got a 1989 GTA, 5.7 tpi with procharger supercharger
had running issues since fitting accel injectors (yes, I now know they are not the ultimate)
what ib/rate injectors would you recommend? car is used for fast road and normal driving so don't want over fueling issues but don't want lean running
thanks John (from UK)
Old Dec 31, 2014 | 11:29 PM
Thirdgen89GTA's Avatar
Transmission: M28 T56
Re: GTA 5.7 injectors
Injector sizing is determined by estimated power output at BSFC. Then you want to keep the injectors sized so they run around 80% duty cycle for headroom.
Some of its guessing unless you know every single detail about the engine. Forced induction engines need more injector than a N/A engine at the same power level.
L98 = 22LB/hr = 245hp
LT1 = 24LB/hr = 285hp
LS1 = 28LB/Hr = 350hp (Late corvette rating)
I'm running 31LB/hr injectors and should be making about 420whp.
Regardless of what you choose, the ECM must be programed for the corrected flow rate (LB/HR @ xPSI) An injector rated 30# @ 43psi will flow more fuel @ 50psi. Making the Injector Constant in the ECM incorrect.
Old Jan 1, 2015 | 05:12 PM
many thanks
much appreciated
Old Jan 3, 2015 | 03:58 PM
not easy to get a trans am ecu reprogrammed over here
could I get away with 24ib injectors without reset?
Old Jan 3, 2015 | 04:04 PM
No.
You'll have to get into programming yourself, there are options in the DIY and tuning forums.
Even if you ran higher fuel pressure to increase the effective flow rate of a 24# injector, you'd need to program the ECM to read that. Anything less will just make for a poorly running car.
Old Jan 5, 2015 | 06:01 PM
southbay08's Avatar
www.southbayfuelinjectors.com
516-442-4707
Old Jan 5, 2015 | 06:11 PM
so best to go for standard 22ib injectors?
the car is fitted with adjustable fuel pressure regulator that came with the procharger
that increases fuel pressure on boost only which can be set to keep air/fuel ratio correct
Old Jan 6, 2015 | 07:49 AM
Those work, but are a bandaid as far as fueling goes. Tons of people have used the rising rate regulators though.
Old Jan 6, 2015 | 02:50 PM
appreciate all the help guys
got any links to diy ecu tuning?
Old Jan 16, 2015 | 04:49 PM
ordered a set from South Bay fuel injectors
very helpful, very recommended
stalkier
Dec 6, 2015 11:25 PM
gta90
Sep 15, 2015 04:00 PM
z28addict8490
Sep 5, 2015 03:56 PM
mrestrictrplate
Aug 27, 2015 09:37 AM
jharrison5
Aug 19, 2015 05:53 PM
