tpi swap
Old Jan 16, 2015 | 01:06 AM
Venom215's Avatar
tpi swap
Has anyone put a tpi in a 84 camaro? If so what all did you have to do to get it to work?
Old Jan 16, 2015 | 10:56 AM
rusty vango's Avatar
Car: 86 IROC
Engine: 5.0 TPI
Transmission: 700-R-4
Axle/Gears: 2.73 open
Re: tpi swap
basically its a wiring and fuel delivery kinda thing. it can best be done if you have a complete donor car to pick parts from
Old Jan 16, 2015 | 11:31 AM
Venom215's Avatar
Re: tpi swap
Thanks for the info
Old Jan 22, 2015 | 06:31 AM
vertisbignuts's Avatar
Re: tpi swap
I have a ecm and wire harness from a 1986 iroc I would sell
Old Jan 25, 2015 | 11:58 PM
Ozz1967's Avatar
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
Re: tpi swap
You will need an ECM and harness from a donor car, or aftermarket. Pocket, a member here on the boards can make them as well. You will need an electric fuel pump, probably an in-tank style. Whalboro 255lph are popular. You will need all the sensors and you will need to upgrade your fuel lines. Your 84 Camaro, same as my 84 T/A, has low-pressure fuel lines with clamps holding rubber hoses onto them at points. You will need to upgrade to high-pressure fittings or replace the whole system with a TPI set up from a later model or steel braided lines.
I've been looking at doing this with my 84 TA so I've been researching it all. Kind of a pain really. Best of luck to you!
Old Jan 27, 2015 | 04:33 PM
Venom215's Avatar
Re: tpi swap
Thanks I didn't know the fuel lines had to be replaced hm sounds like alot of work lol I gotta get some parts together
Old Jan 27, 2015 | 11:31 PM
Ozz1967's Avatar
Car: 1984 Trans Am
Re: tpi swap
Yeah, the carb line are low pressure lines, capable of 20psi or so tops. TPI requires 60PSI of pressure or so, running 24-30lb injectors depending on your application. You just need to bridge the two places where there are rubber lines connected to your hard lines. Near the tank and at the mechanical pump which you'll need to remove and replace with an in-tank pump anyway.
gta90
Sep 15, 2015 04:00 PM
masonta
Aug 31, 2015 10:14 PM
jharrison5
Aug 19, 2015 05:53 PM
st.evel07
Aug 13, 2015 06:15 PM
Sanjay
Aug 12, 2015 03:41 PM
