87 maf to 92 speed density
Old Feb 5, 2015 | 08:33 AM
bamaboy0323's Avatar
I'm converting an 87 maf to a 92 speed density in my 92 TBI camaro.
I know I need a new knock sensor and a MAP sensor but are there any other sensors/parts that I need. I already upgraded the fuel pump and i have 3 TPI units all from 85-88 and don't want to have to buy an SD setup.
Old Feb 5, 2015 | 05:38 PM
MoJoe's Avatar
Car: 87 IROC
Engine: L31 350
Axle/Gears: 4.10 D44
Re: 87 maf to 92 speed density
A block off kit to eliminate the CSI / 9th injector.
Old Feb 5, 2015 | 07:26 PM
89blackformula's Avatar
Car: 89 firebird
Engine: LB9
Your intake plenum would have to be from 90-92 to have the threaded boss for the map sensor.
I am sorry I see tbi! Sorry again
Old Feb 6, 2015 | 03:52 PM
bigal55's Avatar
Car: 88 convertible
Engine: 5.7L
Transmission: 4+3 maual
Axle/Gears: 3.07
He wants to go TPI without having to purchase more parts. The map sensor can be remote mount or the plenum can be drilled and threaded for the correct fitting.
Old Feb 8, 2015 | 08:17 AM
Thanks Bigal,
I almost bought a setup from a 91 but then came across a site that showed it mounted by the firewall.
Old Aug 11, 2015 | 09:09 AM
nuggie's Avatar
Car: 91 Firebird, 87 E'LS' Camino
Engine: 5.7 TPI, 5.3
Transmission: 700R4,200R4
Axle/Gears: 4.10 Lock Right locker/2.43
I know this is kinda old what connection did you use for the Map sensor? Just the one that went to the MAF? So then you just used the ecu from the post 91?
Old Aug 11, 2015 | 09:18 AM
I bought a wiring harness and ecm from a 91 Camaro.
Old Aug 12, 2015 | 06:51 AM
MoJoe's Avatar
Car: 87 IROC
Engine: L31 350
When converting from the 87-89 MAF/x165/2 connector ECM to the 90-92 MAP/x730/3 connector ECM you have to re-pin the connectors at the ECM. You can either re-assign the MAF wires and use them for the MAP, or run new wires.
Here is additional info.
BumpaD82
Feb 26, 2016 02:57 PM
Nick McCardle
Sep 10, 2015 08:36 PM
FLAP
Camaros Wanted
Sep 2, 2015 09:22 AM
