No Idle, excessive fuel, black smoke, loss of power
Old Feb 14, 2015 | 11:28 PM
falak's Avatar
Car: irocz camaro 88
Hey guys I could use some professional help from this forum.
I have a 1988 camaro Iroc z 350 Auto.
I was recently driving it and suddenly after a km or 2 the car started to misfire not idle and give out rich black smoke.
To keep it at idle I have increased the idle speed but its still very rough and its running super rich and there is absolutely no power even with the gas pedal all the way down, still wont go above 2000 rpm ( in gear). People behind me would choke to death.
codes being flashed are
MAT
MAF
Burn off relay
but the interesting thing is that the car was running fine for over a year with these codes but suddenly one day it just collapsed. It has been running without a MAF for over a year now and a faulty MAT but never gave such issues up till now
could you please guide me in this
i have checked the following
tps- ok
spark wires- ok
fuel pump/ filter ok
vacuum leaks- ok
injectors are firing
what other possible fault could it be?
Old Feb 16, 2015 | 08:03 PM
Rolling Thunder's Avatar
Car: 86 T/A, 83 Z/28
Engine: 5.0 TPI, 350 2 X 4 bbl
Transmission: 4 speed auto, 5 speed manual
Axle/Gears: 3.23 posi, 3.73 std
Re: No Idle, excessive fuel, black smoke, loss of power
Check the fuel pressure, fuel pressure regulator diaphragm, and the vacuum line going between the FPR and manifold. Also try dissconnecting the MAF sensor. Lastly, If i recall correctly the ECM will only store up to 3 codes so you may have a host of other issues that are just not displayed when you ring out the codes. Might want to start fixing those existing issues.
Old Feb 17, 2015 | 03:47 AM
falak's Avatar
hey thanks guys.
will definitely try the things you suggested and get back
any other suggestions ?
92camaroJoe
Jul 29, 2023 07:57 PM
1992 Trans Am
May 10, 2023 07:19 PM
theshackle
Sep 17, 2020 08:26 AM
92camaroJoe
Aug 13, 2015 06:07 AM
squiggy2
Aug 9, 2015 09:30 PM
