Why did GM do this?
Old Mar 10, 2015 | 10:13 AM
firechicken1992's Avatar
Car: 92 Firebird--02 Grand Prix GTP 2Dr
Engine: Poncho 400--3.8 Supercharged
Transmission: T56 6 Speed--4T65EHD
Axle/Gears: Open 10 bolt 3.42--Internal 2.93
Why did GM do this?
Looking at my factory manual I noticed that all 8 TPI injectors are fired from a single ECM ground. On the MPI 3.1, the fuel injectors are fired from 2 separate ECM grounds. Why would GM do that to the higher performing model and give the base engine the better route as far as injecting the fuel?
Old Mar 10, 2015 | 03:23 PM
ezobens's Avatar
Car: 69 Corvette
Engine: 409 CID SBC
Transmission: SS 700
Axle/Gears: 3.70
Re: Why did GM do this?
Since all 8 fire at the same time, I don't understand the concern?
Old Mar 10, 2015 | 03:50 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
It may sound crazy, but the wiring and injector grounds for the two are identical. Even though the 3.1 MPFI drawing shows what appears to be two injector drivers, there is only one in the ECM.
The drawing for the TPI setup is more accurate.
Note that the '90 - '92 TPI engines and 3.1l MPFI engines used the same ECM. But with different code bases in each.
RBob.
Old Mar 10, 2015 | 05:44 PM
Ah, well that was simple! Just something that had had stuck out to me when I was looking through diagrams. Makes more sense that way.
