Car runs rough, then dies.
Old Apr 9, 2015 | 01:55 PM
killer777's Avatar
Car: 1989 Firebird Trans Am
Engine: 355
Car runs rough at 1,500 rpm with my foot on the pedal, shoots up to 4,000 rpm, and back down to 1,500. Will die if I take my foot off the pedal. Says I have codes, but it just gives me 12 back.
-tps is new and adjusted
-new fuel pressure regulator
-new injectors
Old Apr 9, 2015 | 02:59 PM
Bob88GTA's Avatar
Car: 88GTA
Engine: 5.7TPI
Re: Car runs rough, then dies.
Search button works.
Follow this procedure to the T
https://www.thirdgen.org/newdesign/tech/tpimod2.shtml
Old Apr 9, 2015 | 07:56 PM
killer777's Avatar
Engine: 355
Alright, but should it rev that high without me doing ANYTHING?
Old Apr 10, 2015 | 06:58 AM
Bob88GTA's Avatar
Car: 88GTA
Engine: 5.7TPI
If those two sensors are not in sync with each other, and the min idle is not set per the procedure, you can/will/possibly have a very high idle.
Also, check all your vacuum lines and make sure you are not sucking additional air. THAT in itself will cause a very high idle.
Old Apr 10, 2015 | 02:49 PM
killer777's Avatar
Engine: 355
Thank you for the detailed reply. It doesn't idle at 4 it just revs to it for some reason. I will do that reset soon hopefully. I'll let you know if it helps. Thank you for the reply, didn't get a lot on my last thread.
Old Apr 10, 2015 | 03:01 PM
Bob88GTA's Avatar
Car: 88GTA
Engine: 5.7TPI
you're welcome, anytime!
angel2794
Theoretical and Street Racing
25
Mar 7, 2026 01:08 PM
kyleb24
Aug 15, 2015 08:24 AM
Kaweh
Aug 9, 2015 02:54 PM
Sherpajames
Aug 7, 2015 06:56 PM
