Emission delete
Old Apr 10, 2015 | 12:52 AM
3rdgenlsx's Avatar
Car: 1991 pontiac trans am Gta
Engine: Lb9 5.0 soon to be L98 5.7
Emission delete
Hi I have a 1985 trans am with a l98 tpi from a 1987 corvette I want to remove some stuff to tidy up my engine bay and there is a lot of emission stuff I am from ontario so any car 1987 and under dont need a emission test so can I remove my emission stuff
Old Apr 10, 2015 | 06:47 AM
killer777's Avatar
Car: 1989 Firebird Trans Am
Engine: 355
Re: Emission delete
Are you asking for help on removing them, or what to remove or just stating that you are going to remove it.
Old Apr 14, 2015 | 06:24 PM
85Special's Avatar
Car: Silver 1985 IROC-Z
Transmission: 700-R4
Re: Emission delete
Smog and cat can go without giving codes. Not sure about egr but I assume it would throw a code.
Old Apr 17, 2015 | 07:38 AM
toronto formula's Avatar
Car: 89 Firebird Formula
Engine: 383 tpi vortec heads Xr 269 cam
Re: Emission delete
Not sure if that year has air pump- but if yes you will probably run lean in closed loop since o2 sensor is expecting air from air pump and not getting it so it will reduce fuel. You will probably need new prom to avoid issue- maybe more experienced guys can give their input
Also, in Ontario apparently moe can pull you over to inspect vehicle and all original smog equipment should be in place even though you don't need a drive clean test. Be sure before you start tearing apart....
jaridjohn
Oct 5, 2015 07:01 AM
racereese
Oct 3, 2015 03:46 PM
djmarch
Oct 2, 2015 10:41 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
