Vacuum hose routing..??
Old Jun 9, 2015 | 01:44 PM
86IROC112's Avatar
Car: 1986 IROC Z
Hi guys,
I searched all over but could not find the answer to this one. I am looking at the routing sticker under the hood and have two questions.
I know one of the hoses goes from the EGR solenoid to the vacuum port under the throttle body but the diagram shows a line from the canister going to the same spot.
Q: do I need to "T" these lines and run them both to the port under the throttle body?
I also know a hose goes from the passenger side valve cover to the upper connector on the passenger side of the throttle body. The diagram shows a line going from the far left side of the canister and routing to the same area as the line from the valve cover. But the diagram just shows it ending there.
Q: Does this line also need a "T" and run both to the upper port on the throttle body?
Thanks!
Old Jun 9, 2015 | 02:34 PM
Bob88GTA's Avatar
Car: 88GTA
Engine: 5.7TPI
Re: Vacuum hose routing..??
See this post. I'll help you out!
https://www.thirdgen.org/forums/tpi/...s+lines+issues.
Old Jun 9, 2015 | 03:19 PM
Bob88GTA's Avatar
Car: 88GTA
Engine: 5.7TPI
PS: Finish your profile so we know what you have as in car,engine, year, trans, location.....
Old Jun 9, 2015 | 03:21 PM
86IROC112's Avatar
Car: 1986 IROC Z
Here is my throttle body. Only has one male vacuum port on the right side???
Attached Thumbnails Vacuum hose routing..??-tb1.jpg   Vacuum hose routing..??-tb2.jpg
Old Jun 9, 2015 | 03:26 PM
Bob88GTA's Avatar
Car: 88GTA
Engine: 5.7TPI
what year?
Old Jun 9, 2015 | 03:27 PM
86IROC112's Avatar
Car: 1986 IROC Z
1986 IROC Z, 305 TPI
Pac J
May 17, 2020 10:44 AM
sheachopper
Jul 31, 2019 11:27 AM
FormulasOnly
Jul 23, 2018 08:47 AM
HoosierinWA
Oct 7, 2015 10:15 AM
dusterbd
Sep 29, 2015 08:40 AM
