Identify this fuel line part please..
Old Jun 11, 2015 | 05:13 PM
MeenZ28's Avatar
Car: 1992 Z28 Targa Top. Full air ride
Engine: 305 5.0 tpi v8
Transmission: A4
Axle/Gears: 3.73 gears posi
This little round flying saucer thing in-line with the fuel line. Can someone tell me what it is, what it's called, what function does it serve and where to find a replacement (if necissary). Thank you.
Old Jun 11, 2015 | 05:54 PM
aliceempire's Avatar
Transmission: T-5, TH350, T-5
Re: Identify this fuel line part please..
Certainly not factory. Either a pressure regulator(doubtful) or a pulsator. A pulsator works kinda like a shock absorber for when the injectors shut, the fuel pressure "spikes". Helps keep the injectors from being extra loud.
BTW, if you haven't already, you might want to fix the line that's not connected to the tank pressure control valve. (the black disc thing below the metal dealie)
Old Jun 11, 2015 | 07:23 PM
greenyone's Avatar
Car: 91 G92 Z28
Axle/Gears: 342
Exactly what alineempire said. That is fuel pressure damper. I tried adding one to my car also to see if it would quiet down noisy Bosch fuel injectors that send pulses through your fuel system. It's most certainly not factory. Oh and it didn't work in shutting up noisy injectors. I would guess a previous owner was trying to do the same thing to your car. It's a real common to see one or more of these on almost all newer cars. Especially imports.
Old Jun 11, 2015 | 10:44 PM
MeenZ28's Avatar
Transmission: A4
Wierd. I kinda suspected that it wasnt factory since no other tpi ive seen (on-line or in person) had it. Thus the reason for my question.
So, logically, it wouldnt hurt anything if i bypassed/eliminated it, right?
Old Jun 11, 2015 | 11:19 PM
Shouldn't hurt anything other than the chance the injectors will get noisier.
Old Jun 11, 2015 | 11:52 PM
MeenZ28's Avatar
Transmission: A4
I can deal with a little extra noise. Thank you guys.
FYI the hose is disconnected from the tank pressure control valve because with it connected the car tends to "moo" randomly when parked. Its kind of annoying.
Old Jun 12, 2015 | 02:23 PM
EDGE's Avatar
Car: 1987 GTA
Engine: 5.7
Transmission: T5WC
Axle/Gears: 3:27
That Moo sound is probably your tank over pressurizing and blowing out through the vent valve normally used to let air in the tank. It will reverse flow if the pressure is to great. Your EVAP system is probably not working.
Old Jun 12, 2015 | 04:43 PM
MeenZ28's Avatar
Transmission: A4
I'm aware of all that. From what I've determined it's probably the EVAP solenoid on top of the charcoal canister that's failed. Unfortunatly I can't replace that with out replacing the whole canister and I don't feel like spending a couple hundred on that just yet. It's just emissions and doesn't seem to effect the car's performance with that hose disconnected to no harm no foul.
Old Jun 13, 2015 | 11:05 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
The CCP solenoid is only used to purge the canister. Has nothing to do with tank pressure. Either the pressure control valve is bad (the round thing you disconnected the hose from).
Or the canister vent has been plugged. This is the one on the top that has molded in 'AIR.'
That is an open air vent and as such needs to be open to the air.
RBob.
Old Jun 15, 2015 | 01:31 AM
MeenZ28's Avatar
Transmission: A4
The pressure control valve (the round black thing i have disconnected) was replaced within the last 6 months (trying to inexpensively fix this issue) and no change - so i doubt its that. The only thing on top of the canister IS the CCP solenoid and as i stated before can not be replaced byitself, the whole canister has to be replalced. See below.
If the solenoid is not the issue then where else should i be looking?
Old Jun 15, 2015 | 08:09 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
The pressure control valve should crack open at under a psi of pressure. Should be able to easily blow through it from the tank side.
The canister side of the pressure control valve goes to the lower port on the canister. Should be able to easily blow into that port. And have the air exit the canister via the vent tube.
The vent is to the left of the solenoid in the picture you posted.
RBob.
Old Jun 15, 2015 | 08:19 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Here are some pictures of the system from the '92 FSM.
RBob.
Attached Thumbnails Identify this fuel line part please..-92_camaro_ccp_0a.jpg   Identify this fuel line part please..-92_camaro_ccp_1a.jpg
Frozer!!!
Jan 19, 2024 04:55 PM
theshackle
Mar 5, 2017 06:37 PM
Andrew6.688
Dec 13, 2015 10:59 AM
AkDrifted
Aug 17, 2015 07:45 PM
1nastygta
Aug 8, 2015 07:38 PM
