intake gasket question
Old Jul 22, 2015 | 05:25 PM
bbsr72's Avatar
Car: 91 formula
Engine: 350 tpi
Transmission: auto
Axle/Gears: poss
got new victor reinz MS15315W. what im questioning is on old gasket way in the back was blocked off with only a small hole in center. these new ones are open. is this going to be a problem or just wrong gaskets?
Old Jul 22, 2015 | 05:52 PM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
Transmission: Custom Built 700R4 w/3,500 stall
Axle/Gears: QP fab 9" 3.70 Truetrac
Re: intake gasket question
Doesn't matter. If you pull the manifold and look at the rear, where those coolant passages are in the gaskets and heads, you'll see that they are closed off in the manifold. This is typical of all SBC V8s.
A sort of exception is some later engines like the Vortec TBIs where the heater inlet takes off from the rear of the passenger side cyl head. There you need a gasket with a open passage.
The passages are in the rear of all SBC heads because the two cyl heads are the same casting. They were designed this way so that one casting can be used for both banks of the engine. Saved production costs. The one difference between the two heads is in some cases the accessory bolt holes are not all drilled in both ends of each head.
Old Jul 23, 2015 | 01:33 AM
bbsr72's Avatar
Car: 91 formula
Engine: 350 tpi
Transmission: auto
Axle/Gears: poss
i didnt even recognize that before.ty.
1992 Trans Am
May 10, 2023 07:19 PM
NinjaNife
Aug 23, 2015 11:49 AM
theurge
Aug 21, 2015 12:46 PM
redmaroz
Aug 16, 2015 11:40 PM
