IAC adjustment and the test drive...?
Old Aug 20, 2015 | 08:07 PM
86IROC112's Avatar
Car: 1986 IROC Z
I have adjusted the IAC according to the instructions found on this site and Chevy Thunder. Both mention driving the car for approximately 20 minutes after adjustment so the car can "learn."
Is that a must and will I not get the results I hope for if I don't drive it afterward? I have not been able to drive the car yet as I am still working on it.
Old Aug 21, 2015 | 10:22 AM
Bob88GTA's Avatar
Car: 88GTA
Engine: 5.7TPI
Re: IAC adjustment and the test drive...?
You will need to drive the car for around 20 minutes. It gives the computer to reset. Letting it sit in the garage or driveway wont cut it. Also, the setting procedure should be done when the car is up to operating temperature.
Old Aug 21, 2015 | 12:10 PM
86IROC112's Avatar
Car: 1986 IROC Z
So this could explain why my idle is still hunting? What kind of driving should I do? Cruising or lots of stop and go??
Old Aug 21, 2015 | 12:13 PM
Bob88GTA's Avatar
Car: 88GTA
Engine: 5.7TPI
I normally go out and drive around forty then up to cruising 55 then come back down. Do some stop and go after that. Then head to the house. Seems to work.
Old Aug 21, 2015 | 12:15 PM
86IROC112's Avatar
Car: 1986 IROC Z
Will do. Thanks for your help Bob. I'm finally almost there...
Old Aug 21, 2015 | 12:39 PM
Bob88GTA's Avatar
Car: 88GTA
Engine: 5.7TPI
No prob...good luck!
Hotrodboba400
Dec 10, 2019 07:07 PM
J-money
Jan 4, 2019 09:45 AM
Jk_Under
Sep 8, 2015 08:13 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
greenyone
Sep 2, 2015 03:39 PM
