WinALDL ver 1.05a, free scanner with support for 1985 TPI
Old Dec 19, 2001 | 09:51 AM
JoBy's Avatar
Car: 1984 Corvette
Engine: Turbo 350
Transmission: 4L80E with TCI T-Com
I just released ver 1.05a.
Added support for 1227165 (1985-1986 TPI, 160 baud only).
I developed this software for 160 baud TBI ECM's but it was easy to add support for the other 160 baud ECM's too. I think that the 8192 baud first came in the 1986 ECM's so the 1985 TPI can't use the same scanners as the newer ECM's.
Check it out here:
http://www.winaldl.webhop.net
I only have access to my own ECM, so I more or less have to develop this software without the possibility to test it. If you find something that is not working right please let me now so I can fix it.
This is the definition I used for the 1227165 ECM:
http://www.isthq.com/~dan/aldl_35.htm
Old Dec 19, 2001 | 10:01 AM
Jim 86 Bird's Avatar
Car: '89 TA
Engine: LB9
Transmission: M5
Awesome
I know '89 TPI's a totally different baud... but is the software capable of handling that baud sometime in the future? Just wondering 'cuz I really like the program
Old Dec 19, 2001 | 10:42 AM
JoBy's Avatar
Car: 1984 Corvette
Engine: Turbo 350
the 8192 baud is very different from the 160 baud, it is a two way communication. WinALDL will probably only support the 160 baud format. I don't know what year GM finally gave it up. Your 89 probably supports the 160 baud too. Of cource it will update much slower than a 8192 scanner, and wilth less data, but it would probably work.
xbmx89
South Central Region
Oct 31, 2015 10:59 AM
Thornburg
Aug 25, 2015 01:46 AM
theurge
Aug 21, 2015 12:46 PM
Electro_X
Aug 19, 2015 07:59 AM
Sanjay
Aug 12, 2015 03:41 PM
