L98 injectors
Old Sep 1, 2015 | 08:04 PM
BAMiller's Avatar
L98 injectors
I am working on a stock 1989 IROC z with a 5.7L engine for a friend. The fuel injectors are all different resistance measurements I will need a whole set of 8 injectors. I was looking at the accel injector sets but there are a bunch of different specs for them. What ones do I need for a good stock replacement no plans to change anything on the engine just want it stock. Do these seem to hold up with all the alcohol in the fuel? if not what injectors do you recommend?
Old Sep 1, 2015 | 08:33 PM
SixSeriesCSi's Avatar
Car: 89 Formula, 85 Trans AM & 91 Bird
Engine: 5.0 CARB, 5.7L TPI & 3.1L V6
Transmission: T-5/700R4/700R4
Axle/Gears: 9 Bolt & 10 Bolt X2
Re: L98 injectors
http://www.summitracing.com/parts/acc-150821
I have a set with less than 1500 miles I just took off. Let me know if your interested...
Old Sep 2, 2015 | 07:12 AM
southbay08's Avatar
Re: L98 injectors
If you want to replace your injectors get yourself a set of 22lb bosch lll's...
tgo members receive 10% off. If you are interested just give us a call we''ll be more than happy to help you
Old Sep 13, 2015 | 01:52 PM
KCG's Avatar
KCG
Car: 89 IROC
Re: L98 injectors
deleted...
Old Sep 14, 2015 | 06:38 PM
BAMiller's Avatar
Re: L98 injectors
The owner decided to go with new injectors I installed 8 new 23lb accel injectors. Seems to have solved the problems running very well.
webeeZ28
Sep 14, 2015 12:00 PM
earlpote
Sep 12, 2015 11:55 AM
92rsvortec350
Sep 10, 2015 10:54 AM
Keiffer76
Sep 9, 2015 08:52 PM
Ranbo108
Sep 9, 2015 12:20 PM
