MAF Delete ?
Car: 1987 IROC Z
Engine: 350 TPI L98 block
MAF Delete ?
I see many TPI setups TPI's with K&N Conical filters right on the throttle body. Is their a Mod I am not aware of that allows you to delete the MAF sensor ?
I have an 87 IROC , and I am trying to resurrect it. Among the parts I am missing is a MAF sensor, and if their is a way to bypass it without effecting functionality, i'd definitely love to put that $100+ dollars into something else.
RobertFrank car for example (thanks)
Car: 1987 IROC Z
Re: MAF Delete ?
Darn it, I had a feeling that might have been the case. I searched all my previous threads as I swore that I had asked the same question many years ago, but couldn't find it. Alright, thanks,
Car: 1983 G20 Chevy
Transmission: 4L60
Re: MAF Delete ?
Some small wiring changes, add a MAP sensor, delete the MAF as well as burn off relays, and run $12P Australian code in your 165 ECM.
Car: 87 IROC Z28
Engine: 355 cid TPI
Transmission: Custom Built 700R4 w/3,500 stall
Axle/Gears: QP fab 9" 3.70 Truetrac
Re: MAF Delete ?
And think hard as to whether you really want to feed your engine hot air right off the radiator. There is a reason why engineers spent time and effort designing the factory air intake to draw cold air from in front of the radiator. The best of both worlds is a MAP(speed density) system with a factory air intake modified to increase airflow. There is a good description of the process on this forum if you search for "high flow air filter lid". I did the mod on mine and it was a job but now it can support my current motor and the bigger motor I have planned. Once the high flow lid mod is done, think about ram air. It's a fairly easy mod on the IROC.
amargari
Nov 10, 2015 02:09 PM
CAMAROBEAV
European Region
Sep 12, 2015 09:34 AM
