TPI throttle body ports need help I'm losing my mind
Old Oct 6, 2015 | 08:46 PM
rhyno811's Avatar
I know someone here can help me.
I have an 86 Camino with an L98 TPI MAF vette motor swap.
I'm losing my mind over the vacuum connections on the pass side of the TB.
Top port runs to pass valve cover and there is no vacuum coming in or out
2nd port is open and pulling hard vacuum. (no Evap canister setup for it to run to). If I try and plug this port it will eventually stall out and if I drive it open it seems sluggish. If I swap the top line to the 2nd and keep the top open it halls *** but I know there's too much vacuum pressure since the Pcv valve is whistling.
What do I do to get this right? Do I need to run the 2nd port somewhere?
Old Oct 11, 2015 | 07:43 AM
Johnny Gun's Avatar
Car: '88 GTA
Engine: 355 SBC, AFR 195 heads, Stealth Ram
Re: TPI throttle body ports need help I'm losing my mind
Top: Cap it off.
Bottom: PCV valve. Try a new valve. Sounds like your might be a little stopped up.
amargari
Nov 10, 2015 02:09 PM
tommy z-28
Oct 6, 2015 10:58 PM
Camaroguy2
Sep 22, 2015 08:22 AM
355tpipickup
Sep 13, 2015 11:35 PM
blackbmagic
Interior Parts Wanted
Sep 8, 2015 10:36 PM
