BAd injector?
Old Oct 7, 2015 | 10:40 PM
lakeffect2's Avatar
Car: 1993 Caprice wagon "Shammoo"
Engine: tpi'd 406, with P4 ebl EBL 730 ECM
Transmission: custom "4L65" swap.
Axle/Gears: 3.42:1 with posi
BAd injector?
In dealing with mt tpi system, I was resetting a number of things like base timing idle, TPS, trying to track iraating behavior. I grabbed the infrared gun, checking exhaust tube temps.
Thoughout warm up and normal idle I noticd Cylinder #2 temps was a few hundred degrees colder than any other tube. While all others were around 600*, number 2 was around 300-350. I looking for causes, and suspect a clogged injector.
Would that make sense to you? any thoughts?
Mark_ZZ3
May 24, 2018 01:02 PM
BOOT77
Oct 17, 2015 12:09 PM
racereese
Oct 3, 2015 03:46 PM
dusterbd
Sep 29, 2015 08:40 AM
corey8084
Sep 17, 2015 02:56 PM
