89 tpi Iroc egr Vacuum solenoid
Old Oct 7, 2015 | 06:34 AM
Pbarnett98's Avatar
Car: 89 Iroc
Engine: 388CI Paxton supercharger
Axle/Gears: 4.10
I need some help. I am trying to reassemble an 89 Iroc tpi 305 originally.( a lot of missing pieces) so I learned on this site about the egr vacuum solenoid. I go buy it and after a lot of reading. I understand what it does and where it goes but my problem is I cant find the electrical connection on the car. I have no more wires left to hook up. So my question is am I wrong on thinking this car uses the egr vacuum solenoid and if I am wrong where do I hook up the vacuum lines from the throttle body and egr valve?? Please Help!!
Old Oct 7, 2015 | 06:46 AM
Bob88GTA's Avatar
Car: 88GTA
Engine: 5.7TPI
Re: 89 tpi Iroc egr Vacuum solenoid
It uses it for sure. Check back by the pass side left of distributor by the firewall. It's got to be there hanging.
Old Oct 7, 2015 | 12:03 PM
Pbarnett98's Avatar
Car: 89 Iroc
Axle/Gears: 4.10
thanks.. I've been looking and cant find it. Started to wonder if I misunderstood what I was reading. Ill keep looking. Thanks again
Old Oct 7, 2015 | 07:44 PM
Pbarnett98's Avatar
Car: 89 Iroc
Axle/Gears: 4.10
Does anyone know what what color the wires are that connects to the egr soleniod? I found a wire but it has a different connector then the one I bought.
Old Oct 7, 2015 | 08:51 PM
Pbarnett98's Avatar
Car: 89 Iroc
Axle/Gears: 4.10
Or a picture of the connector?
Old Oct 8, 2015 | 05:24 AM
Bob88GTA's Avatar
Car: 88GTA
Engine: 5.7TPI
Not off hand. Go to Austinthirdgen.com and pull up your year of car wiring. That solenoid has been discontinued for years. But a 95 Caddy Seville or Deville solenoid works for these. But....you have to change the connector and bracket.
DiabloWS6
Southern California Area
Feb 15, 2016 02:08 AM
KarlJ
Nov 13, 2015 09:48 AM
KarlJ
Oct 9, 2015 03:43 PM
Magman
Sep 14, 2015 01:30 AM
09ave
Sep 7, 2015 06:03 PM
