Help from the TPI Guru's!!
Old Oct 28, 2015 | 06:53 AM
ryeguy2006a's Avatar
Hi there,
I recently bought a 1988 Trans Am with the LB9 5.0 TPI. I bought the car with most of the top end torn apart from the previous owner rebuilding the cylinder heads. I got got to the point last night where I was installing the passenger side TPI runner onto the aftermarket Edelbrock intake. I had no problems. Everything bolted up correctly and the runners were all flush to the lower intake.
Then, when I was installing the driver's side, that's where I ran into an issue. After trying to install the runner to the lower intake without success, I discovered that I may have either a wrong part, or a defective part. Where the lower intake bolts to the runner ports, seems to not sit flush and even? It almost appears as if the runners are either bent, or maybe I have the wrong combination of parts. I have the 9th injector slot in the TPI runner along with the piece off of the fuel rail so I thought that should be correct.
Are the lower base intakes from Edelbrock all the same or are they different from the pre and post 89? Is my intake runner bent? I have some pictures that may help answer some questions.
Here is the Edelbrock base. I couldn't seem to find any part number on it other than the part that says Hi-Flow Edelbrock.
Here are the runner. I tried to take one that shows how it appears bent, or for the later model TPI Base?
Any advice on this would be greatly appreciated.
Old Oct 28, 2015 | 02:36 PM
Re: Help from the TPI Guru's!!
Anyone?
Old Oct 28, 2015 | 02:42 PM
hrspwr's Avatar
Car: 86 IROC
Engine: 350 Vortec TPI
Axle/Gears: BW 3.27
The bad news is that it does look like there is a defect in that part.
The good news is that you can probably still make that one work. As it is not cast there will be a ton of flex.
On the bench - I would start all the bolts and then slowly tighten them all. Should be able to pull everything into place. Once you have a process for tightening it, I would put it into the car. Otherwise, see if you can find a runner.
Old Oct 28, 2015 | 03:26 PM
I am definitely going to give that a try tonight. Thanks for the heads up!
Old Oct 29, 2015 | 06:46 AM
Thanks for the tip! I was able to bend it back into shape and get the top end of my motor bolted back together.
amcnellis
Sep 16, 2015 04:16 PM
R3500
Sep 8, 2015 10:12 PM
hydrolic144
Sep 8, 2015 06:59 PM
09ave
Sep 7, 2015 06:03 PM
BOOT77
Sep 5, 2015 03:55 PM
