Reading Long term fuel trims
Old Jan 20, 2016 | 10:14 PM
86_firebirdTA's Avatar
Car: '86 Trans Am
Engine: 355 TPI
After installing a custom tuned chip and having cold start issues, my tuner told me that he needs see the long term fuel trim data so he see what adjustments are being made so he can adjust the injector settings. How can I read this data? Can I use an OBD1 scanner?
Old Jan 21, 2016 | 06:20 PM
ULTM8Z's Avatar
Re: Reading Long term fuel trims
Yeah, what he's asking for are the BLM's or Block Learn Values. But you'll need to drive around for a while to get the fuel trims established at the various operating conditions. The fueling is based on load and rpm and there's a cell with a fueling value in it for each load and rpm value. You'll want to hit as many combinations of load and RPM as possible during a datalog (i.e., low rpm and high load, mid range rpm, low load, high rpm light load, etc)... The more data he has on your fuel trims, the less iteration should be expected.
Old Jan 21, 2016 | 08:46 PM
Car: '86 Trans Am
Engine: 355 TPI
Thanks!
camarorsssss
Convertibles
31
Jul 9, 2016 07:43 PM
acliad
Feb 2, 2016 10:30 AM
soarestransam
Brakes
Jan 12, 2016 01:21 PM
irocdls1
Jan 4, 2016 06:33 PM
FormulasOnly
Jan 2, 2016 08:37 PM
