Custom LED Gear Indicator Mod
Old Jan 6, 2016 | 02:51 PM
acliad's Avatar
Car: 84 Z28
Owing to the distinctly lackluster shift plate light on the early 80's Camaros, I came up with an idea for building something a little bit cooler. I actually completed this a while back, but just got around to taking some final pictures. The car is a 1984 Z28, I used an ATTINY and a shift register as the control for the LEDs, and some hall effect magnet sensors to detect the selected gear. I'm quite satisfied with it:
Some breadboard testing
Testing the sensor alignment with a mockup board
Control board PCB layout
One of my bad LED board cutouts (I cut the boards with a CNC, and was still learning)
Where the lights will go
Marking and punching
Sorry, at this point I got excited and forgot to take lots of pictures. Here it is attached to the shift plate. You can see the LED board on the left soldered to the control board with solid copper wire.
LED Board on the top
The sensor board. The mounting tabs have slots cut in them for adjustment.
What it looks like
And a video
Old Jan 6, 2016 | 02:56 PM
the_nikfive's Avatar
Car: Pontiac Firebird 1992
Engine: 191 V6 3.1
Transmission: Automatic
Re: Custom LED Gear Indicator Mod
Very cool!
Old Jan 6, 2016 | 04:24 PM
AmorgetRS's Avatar
I really like the way it lights up the whole thing and then fades out. Very impressive project!
Old Jan 6, 2016 | 07:00 PM
mjdavis68's Avatar
Car: 88 IROC Z/28-under re-construction
Engine: 5.7 Tuned Port
Transmission: It's in there....
Axle/Gears: 9 bolt Borg-Warner
wish i understood how to do that.... super nice
Old Jan 7, 2016 | 01:10 AM
Twin_Turbo's Avatar
market these please... simply awesome. Together with some red glow gauges like the prosports this is an awesome look...add a humount and it's all there
Old Jan 7, 2016 | 08:13 AM
Camaro86IrocZ's Avatar
Car: '86 Iroc Z & '91 RS
Engine: 305 TPI & 305 Qjet - Future LC9
Like..
Old Jan 7, 2016 | 10:40 AM
crazynights's Avatar
Car: 1982 Z-28
Engine: 383
Transmission: Turbo 350
Axle/Gears: Det. Posi, Superior Axles, 3:73 G
Could really use one for my Megashifter!! Plan to make more
Old Jan 7, 2016 | 11:40 AM
acliad's Avatar
Car: 84 Z28
There was someone a while back who made something very similar, except they used a small window to indicate the gear the were in, rather than the factory shift plate. https://www.thirdgen.org/forums/inte...dicator-t.html
It wouldn't be difficult to adapt mine to do the same thing.
I could certainly make some more. I'm not sure what all years it would be a drop in for. I know the shift plate was changed at some point, and the boards are specifically designed to fit on the one I have. Hit me up if anyone is interested. I just moved and don't have access to the CNC anymore, so I would have to order the boards.
Old Jan 7, 2016 | 04:44 PM
AmpleUnicorn88's Avatar
Engine: 305 TBI/305 TPI
Transmission: World Class T5/missing
Axle/Gears: 3.08/G92 3.45 posi
I remember my buddy wanted to make a light up shift know similarly to this. This is pretty cool.
Old Jan 15, 2016 | 04:10 PM
jkris53406's Avatar
Car: 87 Formula, 91 Trans Am
Engine: 355 tpi, 305tpi
Transmission: 700r4, 700r4
Very awesome. Please start making these!
Old Feb 2, 2016 | 10:30 AM
liquidh8's Avatar
Car: 1981 Buick Century Wagon
Engine: 87 GN engine
Transmission: 2004R
Very cool!
