Throttlebody ?
Old Feb 4, 2016 | 07:18 PM
Americanmouse's Avatar
Car: 1988 IROC-Z28
Engine: L98(383tpi) modified
Transmission: 700R4 rebuilt
Axle/Gears: 3:73 10bolt rebuilt
Throttlebody ?
Hey Guys,
I have a modified 1988 883 TPI IROC Z-28.
And currently I'm using a 58MM BBK throttle body. I've been offered a 62MM BBK with the TPS senser. Is it worth the swap?
Old Feb 4, 2016 | 07:21 PM
mjdavis68's Avatar
Car: 88 IROC Z/28-under re-construction
Engine: 5.7 Tuned Port
Transmission: It's in there....
Axle/Gears: 9 bolt Borg-Warner
Re: Throttlebody ?
with that monster 883 i doubt it
Old Feb 4, 2016 | 07:52 PM
Car: 1988 IROC-Z28
Re: Throttlebody ?
So your saying the 62mm is to small?
Old Feb 4, 2016 | 07:56 PM
Car: 1988 IROC-Z28
Re: Throttlebody ?
Just a little more info. about my roc.
the intake, runners, are Edelbrock plenum is stock everything is ported and simeased. Also using AFR heads. Also cold air induction, and a reprogrammed chip.
Old Feb 4, 2016 | 07:58 PM
mjdavis68's Avatar
Re: Throttlebody ?
ok,ok... it's a 383 right?
Old Feb 4, 2016 | 08:04 PM
Car: 1988 IROC-Z28
Re: Throttlebody ?
yes a 383
Old Feb 5, 2016 | 11:00 PM
ULTM8Z's Avatar
Re: Throttlebody ?
Unless you think you're pulling over 900 cfm, even a 52 mm should be sufficient for a 383.
https://www.thirdgen.org/forums/alte...ctor-info.html
TPI/LT1 52mm Throttle Body w/ airfoil -- 898.8 cfm
Old Feb 11, 2016 | 08:27 PM
Car: 1988 IROC-Z28
Re: Throttlebody ?
thanks for the replys!
jonarotz
May 25, 2017 11:07 AM
IROCZDAVE (88-L98)
Mar 20, 2016 07:06 PM
Jailescape
Jan 31, 2016 02:47 PM
Jailescape
Jan 27, 2016 08:53 PM
FiVe KiLLZ
Jan 17, 2016 12:52 AM
