what is the pupose of torque converter?!?
Old Dec 22, 2001 | 09:33 PM
lancer5067's Avatar
I have strong knowledge of engine operation and troubleshooting but transmissions are chinese. All I know is the torque converter sits between the flywheel and the auto tranny and you put tranny fluid in it. I believe it has something to do with when the tranny shifts or acts as a clutch but I have no idea.
Could somebody please enlighten me, also I see people here swapping for aftermarket converters, what are the advantages and estimated performance improvements of a higher or lower stall(?) or whatever. Thanks a lot!!!
Old Dec 22, 2001 | 10:20 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
Here's some good reading for you
http://www.howstuffworks.com/category.htm?cat=Transm
Old Dec 22, 2001 | 10:55 PM
lancer5067's Avatar
Thanks a lot! That site pretty much sumed up my Q's, I had to go to a link on there for the performance aspect of it, though. I appreciate it, and for everyone, here's a quick excerpt from the site that pretty much answered my question. Thanks!!
Why do I need a higher stall speed converter?
Theoretically, for maximum acceleration the stall speed of the torque converter should match the peak torque rpm of the engine. A good explanation for the way it works is this: when you go outside jogging you start to breathe in and out faster and harder. Well the same thing goes for a performance engine. The engine is breathing in and out harder and faster, at a higher rpm. If a high performance engine makes power at a higher rpm, then a higher stall speed torque converter is what you need to put more power to the ground quicker.
Why is a torque converter the best performance upgrade money can buy?
No other upgrade to your vehicle can affect your performance better than a torque converter, except maybe nitrous oxide or possibly a supercharger. Consider the price of a supercharger, or the potential damage of nitrous in comparison to the cost effectiveness of a torque converter upgrade. Tests have shown that the correct torque converter can reduce 1/4 mile times by .3 to .7 seconds. And you get this benefit every time you step on the gas in everyday driving.
seiplentz
Aug 19, 2019 06:02 PM
88rscamar0
Sep 23, 2015 09:08 PM
Ragtop Man
Sep 12, 2015 12:23 AM
Nick McCardle
Sep 10, 2015 08:36 PM
