losing fuel pressure
Old Feb 21, 2016 | 09:40 PM
xodus2002's Avatar
Engine: 305 tpi
85 tpi 305. Hard to start after sitting overnight. Once i get it started it has a rough idle for about 5 minutes then idles normal. I've hooked up a fuel pressure gauge to the Schrader valve on the rail and get 35psi when the pump primes but once i turn the key off it drops to 10psi then 0 after about 5 minutes. Has new filter, pump, and regulator. I've pulled the rails and checked the injectors and no leaks. What else should i check?
Old Feb 21, 2016 | 09:50 PM
FBFAN's Avatar
Car: 91 Firebird
Engine: V-6
Re: losing fuel pressure
Fuel Lines and Fuel Pump.
jonarotz
May 25, 2017 11:07 AM
rusty vango
Jul 5, 2016 03:09 PM
mpoit957
Jan 30, 2016 12:26 AM
Crossfiresuck
Jan 28, 2016 08:13 PM
R3500
Jan 24, 2016 07:50 AM
