Intake mods on a 305?
Old Mar 7, 2016 | 11:12 PM
ZsTransAm's Avatar
Car: 89 Trans am
Engine: 5.7 TPI
Now that I've collected the parts to do full exhaust and a gear swap this summer, I want to start saving towards the next upgrade. I've been thinking of doing intake mods (probably aftermarket base, runners, ported plenum, and possibly an adjustable fuel pressure regulator while I'm there) since the parts can be used if/when I eventually upgrade to a 350. From what I've seen on here, almost everyone who does it seems to do it to a 350, not a 305. Is it still worth it to do, or would I not gain enough for it to be worth it?
Old Mar 8, 2016 | 05:43 AM
luvofjah's Avatar
Car: 91 Black Formula KR
Engine: 305 TPI R69/G92
Re: Intake mods on a 305?
All that expensive ported / high flow stuff would not produce much with stock heads & cam on the 305... I've seen posts of people with 305's use aftermarket base, runners... some said they had a slight gain, some lost, and some said no difference...
They will make a bigger difference on a 350....
Old Mar 8, 2016 | 07:39 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
It should still help extend the rpm range if you add siamese style runners and 1.6 rockers. Should be a slight gain
Old Mar 10, 2016 | 11:25 PM
ZsTransAm's Avatar
Car: 89 Trans am
Engine: 5.7 TPI
Doesn't sound like the best gain for the money spent, I might just save to do a swap sooner and worry about intake mods after that then. Thanks for your replies
Old Mar 28, 2016 | 09:50 PM
jaridjohn's Avatar
Car: 92 z28 convertible
Engine: 305 tpi
Axle/Gears: 2.73 to1
Your 305 intake upgrades will work for your 350.
scoutcamper
Apr 8, 2016 12:30 AM
BOTTLEDZ28
Brakes
Feb 21, 2016 11:44 AM
Eric-86sc
Convertibles
Feb 19, 2016 08:53 PM
66_C10_TPI
Feb 16, 2016 04:24 PM
Immrpablo
Feb 7, 2016 05:23 PM
