What is my engine suppose to idle at?
Old Dec 23, 2001 | 10:35 PM
Dmook62's Avatar
I think my engine is bogging out because it idles to low! I is idling at 5...wht is it suppose to idle at? Any help would help thanks.
Old Dec 24, 2001 | 02:33 AM
DANIELEK's Avatar
Car: Red Rooster
Transmission: M5
650 - 700 RPM. Try that.
Old Dec 24, 2001 | 05:30 AM
90Iroc's Avatar
Car: 1990 Iroc/Z
Engine: LB9 305 TPI
Transmission: Borg Warner 5 speed
It also depends on your transmission too. Do you have a manual or automatic? For a manual try 500 RPM in drive. For a manual try 750 in neutral. Before you adjust the set-screw on the Throttle body, see if your TPS sensor is out of adjustment.
Old Dec 24, 2001 | 04:28 PM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
The TPI instructions from FIS says 450rpm for 283-305.
400rpm for 327-400.
Above is for automatics when in drive.
For a manual car, 500rpm in neutral.
eightsixseven
Dec 16, 2024 01:50 PM
backtothe80s
Sep 5, 2015 12:39 AM
db057
Aug 22, 2015 08:17 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
