Ignition setting hood decal pictures
Old May 16, 2016 | 05:09 AM
zuhi's Avatar
Car: 1991 Pontiac Firebird
Engine: 3.1L 189CUI
Transmission: 4spd Automatic
Dear Members!
I would like to ask some help!
I need to set up the ignition on a 1988 Pontiac Firebird Trans AM GTA which has a MAF sensor TPI 5.0L engine.
The car missing the factory recommended method stickers from the hood.
Now runs very advanced i think it needs some retarding.
So please, if some has the same engine and have the original emission and ignition setting decal on its hood please picture it in readable resolution!
I'm happy for any help!
Best Regards:L.
Old May 16, 2016 | 06:57 AM
eseibel67's Avatar
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
Re: Ignition setting hood decal pictures
6 degrees advanced in bypass mode.
Old May 16, 2016 | 09:06 AM
zuhi's Avatar
Engine: 3.1L 189CUI
OK And which position i should check?
P N or D with handbrake engaged? the car us Automatic i just forget to mention.
I read a similar sticker years ago, but I do not remember the process well.
I know i need to unplug the single brown wire near at the blower motor to bypass the ECM distributor control.
Otherwise the engine is stock, no modified parts in it. I mean crank, pulleys, or camshaft or timing set. So factory settings should work well.
Glad for any future help!
Old May 16, 2016 | 09:25 AM
Bob88GTA's Avatar
Car: 88GTA
Engine: 5.7TPI
Automatic....In PARK
Old May 23, 2016 | 04:39 PM
zuhi's Avatar
Engine: 3.1L 189CUI
Spark plugs cleaned, ignition set to before 6, and cars runs and drives as it should
Thanks for the infos. Interesting if the car sits a few day after it will start only for the 2nd or 3rd try. I think this is a fuel issue and because it was time i replaced the fuel pump last year ( in oktober), and this wasn't solved this problem. As i think, the fuel drains from the fuel rails or something.. And the 5 sec pump at the on key state not enough to feel the system up just for one try.
Any tip for these issue?
THIRDGEN87
Interior Parts Wanted
Aug 24, 2023 01:01 PM
xbazzarex
Sep 11, 2016 02:38 PM
xbazzarex
Aug 27, 2016 07:18 PM
xbazzarex
Exterior Parts for Sale
21
Aug 27, 2016 07:17 PM
Scorched1984
Apr 13, 2016 06:07 PM
