runs like crap
Old Dec 28, 2001 | 01:25 PM
allrog214's Avatar
runs like crap
just put a new 350 into my 89 iroc, it runs like **** at certin rpms the car will start jerking and hesitate. the only code i get is the the TPS has low voltage. whats the OEM setting for that and could it be any thing else like the fuel pump. thanks
Old Dec 28, 2001 | 03:25 PM
rezinn's Avatar
.54v at idle, 4.0v at WOT.. could be many things, but just start with the most obvious first. Try going from closed to WOT with a voltmeter hooked up and see if the tps makes a smooth transition, if not replace it. Good luck.
Old Dec 28, 2001 | 03:47 PM
nblanchard's Avatar
Yeah.. try the PS first, unless you like dropping the rear end to get the tank out of the car
Old Jan 2, 2002 | 06:07 PM
allrog214's Avatar
well i replaced the tps and the distributor cap and rotor and now the dam thing won't start. it fires up but then it dies right after and i don't know what the hell to do.
Old Jan 2, 2002 | 06:15 PM
rezinn's Avatar
Things just happen like that, huh? Make sure all of the wires are on correctly and the tps is adjusted correctly. Has to be one of those things if thats all you touched
eightsixseven
Dec 16, 2024 01:50 PM
92camaroJoe
Jul 29, 2023 07:57 PM
9192camaro
16
Feb 3, 2019 12:21 AM
perZ
Aug 21, 2015 05:51 PM
92camaroJoe
Aug 13, 2015 06:07 AM
